Indigo Prop
Old Marine Engine » Palmer Engine Co » Indigo Prop « Previous Next »
Lonnybr
Posted on Monday, April 07, 2008 - 08:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I put the Indigo prop on my Morgan 35 I now run at 2200 to 2400 rpm is that to high?? Old prop ran ar 1600 to 1800 rpm. The p60 uses less gas and seems to like the higher rpm but it just sounds like I'm pushing it too hard any thoughts??
Richard Shapiro
Username: mainesails
Post Number: 59
Posted on Monday, April 07, 2008 - 09:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
No! It's perfect. Higher revs = more noise, but the engine will be happier and the boat will go better. You'll get more thrust and cut through chop better too.
