Photo test
Old Marine Engine » Practice posting here » Photo test « Previous Next »
John Davis
Username: johnny
Post Number: 157
Posted on Monday, March 03, 2008 - 09:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
http://www.antiquengines.com/images/Florida_Flywheelers_Feb_2008_1.JPG
Clive Boyle
Username: klondyke
Posted on Monday, March 17, 2008 - 12:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi out there/hear.
Hope you can help a new STUART fan...fingers crossed.
My P66D, inboard of 19' sail boat, WILL NOT RUN.
It was running greate, before I bought it from a friend, and since.
I got it home, took out engine, gave it a thorough going over,takeing apart,& re-placing where necessary,re wire,etc. stopped short of stripping engine propper.so not effecting timeing.
Put engine back,fired up,and ran sweet as before.
Now, 6 months later no go.Boat has been under good roof cover,protected from the elements.
I have tried:
1)Fresh fuel:50:1 & 55:1 same outboard oil as be fore.
2)Remove float,blow through jets etc,
Solex carb.
3)Plugs are NGK B5HS No1 & B6HS No2,& have good spark.
4)Drain crnk.case of flooded fuel after each attempt.
Throttle,&choke all work ok.Good battery gives good turn over speed, resulting in some exhaust gasses from exhaust pipe, withe occasional back fire,& also occasional spits of exhaust gas from carb.
It just dos'nt fire up, and I don't swear at it....honist.
Any advice would be much appreciated.
