Clae gearbox torque problem
Old Marine Engine » Gears, Transmissions, and Propellers » Clae gearbox torque problem « Previous Next »
Tim Barrenger
Username: timb
Posted on Sunday, January 16, 2011 - 09:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi all,
FWD ok
Reverse no torque, how can i adjust?
Tim
Todd Vidgen
Username: todd_vidgen
Post Number: 199
Posted on Sunday, January 16, 2011 - 09:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
No Torque,or slipping?
If it is slipping you can adjust the reverse band
by loosening the lock nut on the out side of the box
(port side ,halfway along box)and then tighten
the inner nut until you achieve the desired results.
Re-tighten lock nut.DONT OVER ADJUST,as this can add
drag causing heat and wear when in fwd gear.
No torque could be an over adjustment of the fwd
adjustment,creating drag when in reverse
Tim Barrenger
Username: timb
Posted on Monday, January 17, 2011 - 06:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Todd, i'll give it a try today
