How to use reverse pitch propeller
Old Marine Engine » Practice posting here » How to use reverse pitch propeller « Previous Next »
jerome blumberg
Username: jerome
Posted on Wednesday, November 19, 2008 - 06:41 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just acquired a norwegian boat with Marna 5hp engine. It has a clutch with a lever and also a reverse pitch propeller system, with another lever. To operate the reverse pitch do I have to put first the clutch lever to neutral or can reversing be done when the engine is in gear? What is the procedure?
Andrew Menkart
Moderator
Username: andrew
Post Number: 972
Posted on Tuesday, December 09, 2008 - 09:45 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jerome,
You should post that question in the Gears Tranmissions, and Propellers category, not here in the testing area.
Thanks.
