tim rempel
New member Username: oldscool
Post Number: 1 Registered: 02-2008
| Posted on Wednesday, February 27, 2008 - 10:15 pm: |
I realize this board is more about older engines but I am at my wits end trying to date and model this motor.It's an Evinrude 8hp. On the side of the transom mount there is a number stamped, 98EV813A961. You can see where the nameplate used to cover this number. Any help would be much appreciated. |
Andrew Menkart
Moderator Username: andrew
Post Number: 920 Registered: 11-2001
| Posted on Thursday, February 28, 2008 - 10:38 am: |
98EV813A961 is not a valid model number. Sometimes the model number is stamped into a freeze plug on a cylinder, or into the flywheel. If not you could try posting a photo on the MarineEngine.com discussion board in the Evinrude Category. Also see Evinrude info here. |
tim rempel
Post Number: 2 Registered: 02-2008
| Posted on Thursday, February 28, 2008 - 10:18 pm: |
Thanks Andrew, I found the number on the freeze plug. My understanding is that based on CD8RCDE my motor is a 1986 but I don't understand the first D. Thanks again. Tim |
Andrew Menkart
Post Number: 923 Registered: 11-2001
| Posted on Friday, February 29, 2008 - 10:31 am: |
Are you sure it isn't an E instead of a D ? Either way I wouldn't worry about it. Additional questions about that 1986 motor should be placed on the MarineEngine.com board. Thanks. |
William Gage
New member Username: billg
Post Number: 1 Registered: 04-2008
| Posted on Monday, April 14, 2008 - 08:01 pm: |
Same here, cannot get a reply from some of the other forums..Hoping that you could help me also ? I have a small outboard Johnson/Evinrude that I cant date Maybe you could help. Stamped on the freeze plug is B 04451 J 5BFORM |
William Gage
Post Number: 2 Registered: 04-2008
| Posted on Monday, April 14, 2008 - 09:21 pm: |
correction B 04451 J 5BFCRM I just found out that this is a 1984 Johnson 5 hp But I still have a couple of questions. This outboard has a 2 prong plug on the on the opposite side of the F N R lever..Would you know what this for? Also..would you know the fuel oil ratio? } |
