Photographing documents
Old Marine Engine » Miscellaneous » Photographing documents « Previous Next »
searcher
Username: searcher
Post Number: 210
Posted on Saturday, November 24, 2007 - 03:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can anyone suggest a source for learning how to set up for taking good, clear, digital photos of ads in early magazines such as the Rudder, MotorBoat, etc? A scanner is often not available and old magazines don't lend themselves to lying flat on a scanner without damaging the spine. Same with old engine catalogs. My digital camera set on macro will get usable images but the gray background cast, barrelling, and skewing are problems.
Post Number: 298
Posted on Sunday, November 25, 2007 - 04:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have used a pane of glass to flatten the page without damaging the spine. It can get fussy though to avoid glare from the sides
Buzz Bradley
Posted on Sunday, November 25, 2007 - 05:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Miro have you tried the non-glare glass (as used in picture frames)?
Buzz Bradley
searcher
Username: searcher
Post Number: 212
Posted on Monday, November 26, 2007 - 05:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Miro and Buzz,
Thanks for commenting. I will chase down the non-glare glass, didn't know there was such a thing.
searcher
Username: searcher
Post Number: 221
Posted on Wednesday, January 23, 2008 - 02:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A local glass company had a perfectly sized piece of non-glare glass on the scrap pile and gave it to me. Yes, that works quite well to flatten the page as well as avoid the glare associated with a typical pane of glass.
For lighting, I bought a pair of deeply discounted parallel arm desk lamps. I bought two cheap bathroom bar type light fixtures that each held three standard bulbs. I attached these light fixtures on the desk lamps, replacing the original wimpy setup, and screwed in 3 daylight corrected compact flourescent bulbs in each. The result is a pair of an infinitely adjustable lamps with more than enough light output and coverage to eliminate any shadows.
