Pre-oil before starting
Old Marine Engine » Miscellaneous » Pre-oil before starting « Previous Next »
ldobbins
Username: ldobbins
Posted on Wednesday, September 14, 2005 - 12:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Greetings fellow motorheads!
I am looking for a 12 or 24 Volt oil pressure pump. I wish to pre-oil / "float" my crank and build some pressure before ever turning on the ignition and hitting the starter motor.
Thanks,
Lew The West Coast Sterling Guy
Frank Johnson
Posted on Thursday, November 08, 2007 - 02:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The easiest solution is to order an engine pre-lube kit with all the parts from www.autoenginelube.com
Everything is includes and it uses only filtered oil not the dirty oil from the bottom of the pan.
