1953-54 evinrude outboard
Old Marine Engine » Boats with Early Inboards » 1953-54 evinrude outboard « Previous Next »
larry
Username: larry
Posted on Friday, October 05, 2007 - 07:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i tried to get my motor started today.but after i got it started i noticed that ther was no water shooting out the lower unit.i had plenty of water in garbage can.is this something that is expensive to fix.also drained lower gear oil and unfortunetly not much oil came out mostly water.motor has been sitting for 6 years.thanks if someone can tell me.
foxman
Posted on Friday, November 09, 2007 - 09:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Suggest replacing water in lower unit with outboard gearcase oil C insert tube nozzle in lower unit lower oil plug and squeeze until oil comes out top oil plug. Before that you may need to replace pump impellor. Age and neglect may have contributed to its decline and that may be why no water is getting through.
Robert Pray
Posted on Friday, November 16, 2007 - 08:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sounds like it's been sitting a while. That vintage engine probably has the split case lower unit. Parts can be found. You probably will want to replace the seals, water pump impeller etc. Get a manual. All easy to do if you are slow and careful. Keep the bearings in place with grease when you reassemble. If by chance you find the empeller intact, there is a chance of a bad head gasket. That could pressurize the water jacket. But, my money is on the water pump. Oh, never, ever run dry, even a few seconds can take out a dry pump.
Good luck!
