Sprocket missing every other tooth
Old Marine Engine » Gears, Transmissions, and Propellers » Sprocket missing every other tooth « Previous Next »
john rendemonti
Username: rendo
Post Number: 13
Posted on Wednesday, April 02, 2008 - 11:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My hand crank sprocket is missing every other tooth. appears to be a 1/2 pitch if the tooth was there. Where do I find chain for a sprocket missing every other tooth? Thanks. John
484-459-0880
George P Dorris
Username: rusthunter
Posted on Thursday, April 03, 2008 - 01:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This type of chain is called block chain. The last time I bought some was from Boston Gear. I called them this morning but they seemed clueless. The chain that I have is 1" pitch 1/4" wide. As I remember that was all I could buy. Have not located a source for sprockets yet, if I get time I will try again.
john rendemonti
Username: rendo
Post Number: 14
Posted on Thursday, April 03, 2008 - 10:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I found an engineer at Diamond and he advised me that it is called "laminated block chain". I googled it and found a source, horribly expensive, but still available. My sprocket is .350, much wider than bicycles of the early days.
John
Rob Rowe
Posted on Friday, April 18, 2008 - 07:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I noticed some Meadows marine engines on EBay are these of interest to anyone,there was 3 days to go.
Andrew Selman
Username: andys
Posted on Friday, April 18, 2008 - 08:18 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Rob
Do you have the ebay references? I did not see them.
Andy
