Fresh Water P-60 For Sale
Old Marine Engine » Palmer Engine Co » Fresh Water P-60 For Sale « Previous Next »
Scott Helgesen
Username: paperboy
Post Number: 21
Posted on Wednesday, January 07, 2009 - 07:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Were are doing a re-power in our boat. The the big piece of our restoration. The palmer has been a great motor for the 2 years we have owned the motor. New fuel pump last year. The motor is still in perfect running condition and had a top end re-build I want to say around 2004 and have the reciepts for it. The motor will be coming out in the next few weeks, and is located in Michigan. Not sure what its really worth let me know if your intersted. Would like to sell complete but will consider parting out.
Scott
jshelgesen (at) gmail.com
Post Number: 703
Posted on Wednesday, January 07, 2009 - 07:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Straight Drive or V Drive?? Serial number of engine? These are questions you may get. V drives are hard to find.
Scott Helgesen
Username: paperboy
Post Number: 22
Posted on Wednesday, January 07, 2009 - 08:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I will have to get the serial number next time I am at the boat. And its a V-drive with a walter v-drive.
Post Number: 704
Posted on Thursday, January 08, 2009 - 05:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I take it the V drive is independent of the P-60 reverse gear. If it is part of the reverse gear then the P-60 could be more attractive in a sale.
Scott Helgesen
Username: paperboy
Post Number: 23
Posted on Thursday, January 08, 2009 - 06:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
anyone have any idea what the p-60 might weight? thanks
Post Number: 705
Posted on Thursday, January 08, 2009 - 08:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
P-60 weighs 350lbs. with straight drive with built in V drive add 30 lbs.
Gordon Greene
Username: gord
Posted on Tuesday, June 22, 2010 - 03:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
where can i find a new thermostat 160-170 degrees
for my p-60 engine?
B Sidaway
Posted on Wednesday, June 23, 2010 - 12:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Try Moyer Marine, $26 I think.
Eddie Ross
Username: eddie
Post Number: 248
Posted on Wednesday, June 23, 2010 - 10:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I trust that you are operating on a lake and not the ocean. That is too hot for salt water.
