Post Number: 128 Registered: 12-2003
| Posted on Friday, March 16, 2007 - 12:47 am: |
Here is a small unknown I picked up 2 years ago. It has a very interesting gear driven water pump located under the main front bearing. anyone with any idea?
graynorth
New member Username: graynorth
Post Number: 1 Registered: 11-2007
| Posted on Friday, November 02, 2007 - 10:55 am: |
I have a 1902 single cylinder two stroke engine which runs, but not reliably. Apparently, it requires a new "wet sleave" which should increase the crankcase pressure and reload the upper combustion chamber. Can anyone suggest a reliable firm to undertake the work??? Hope you can help. |
Senior Member Username: miro
Post Number: 296 Registered: 11-2001
| Posted on Sunday, November 04, 2007 - 10:57 pm: |
Before you do that - which is a major job - remember that 80% of carb or fuel problems are electrical. If you don't have a good, hot, reliable spark - you'll be fussing with the engne everytime you go to run it. miro |
