4 acadia Grease for cups??
Old Marine Engine » Acadia » 4 acadia Grease for cups?? « Previous Next »
Matt Glover
Username: mjglover
Posted on Friday, June 18, 2010 - 11:28 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i am new to these engines, i bought a 4 acadia in great shape, and working, i have also bought a 20 ft motorboat and am in the process of fiberglassing her now, boat is also in great shape. glass just is to preserve her for a long time. i don't know what kind of grease to use in her cups, and i don't want to take a chance on using the wrong type, any help is appreciated. also looking for some parts or complete engine depending on price. i am in central newfoundland
Bruce Hall
Username: bruce
Post Number: 227
Posted on Friday, June 18, 2010 - 08:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think you will quickly regret fiber glassing your boat if it's wood.Glassing promotes rot and a stiff riding hull-turn back now if you can....
Matt Glover
Username: mjglover
Posted on Friday, June 18, 2010 - 09:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i ment to preserve her shape, all plank will be removed
Frank Petran
Username: frank_petran
Post Number: 116
Posted on Friday, June 18, 2010 - 10:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Almost every wood boat restorer including myself will tell you never fiberglass a wood boat. a wood boat was designed to flex. I agree with Bruce Hall, the boat will become stiff and will not have that nice easy and comfortable ride that it was designed to do. You would be better off if you used the boat as a mold and made a fiberglass hull from it.
Matt Glover
Username: mjglover
Posted on Saturday, June 19, 2010 - 12:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
basicially what i'm doing, is getting a mold from it, all the wood will be removed, like my other 22 foot motorboat but that one has a 33 yanmar in it..
Matt Glover
Username: mjglover
Posted on Saturday, June 19, 2010 - 12:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
so does anyone know what type of grease i can use in a 4 acadia in the grease cups??
Post Number: 872
Posted on Saturday, June 19, 2010 - 06:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I use old style water pump grease. You may be able to get it from Bob's Antique Auto Parts Inc. PO Box 2523,Rockford, IL., 61132
Tel: 815-633-7244, Fax: 815-654-0761
888-663-3581 Toll Free. Tube about the size of a small caulking gun tube.
It seems to work better than wheel bearing grease which is much thinner. Keep in mind in operation you should give the grease cups on the crankshaft a 1/4 to 1/2 turn about every 20/30 mins. Hey no one ever said running one of these old timers in a boat was a walk in the park!!!!. Myself I stick with 40/1 SAE 30 non detergent oil/gasoline mix. Others use modern two stroke oil 16/1, I think. Guess it depends on your age.
John Archibald
Username: john_archibald
Post Number: 141
Posted on Saturday, June 19, 2010 - 07:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have been using some Molybdenum Grease on my 8 Hp. Acadia with apparent success.
Almost any grease will work for these crude engines. Back in 1904 things were not as sophisticated in the lubrication world as they are today.
You could also used a Lithium Grease which is available at any automotive parts store, etc.
The main thing is to give the caps a 1/4-turn every time you run the engine. If it is running in a boat for an hour or more at a crack, give it such a twist every hour or so.
This will prolong the life of your Babbitt bearings. It will also help to seal the crankcase. Otherwise, the oil/gas mixture can squirt past the bearings and eventually "wash" them clean of any grease. In the long run this is not good. However, Babbitt being what it is, the engine will run for a long time without "any" grease present. A thin film of grease and oil will persist that will protect the bearing and shaft.
So there you have it.
Archibald
Northfield, Minnesota
Matt Glover
Username: mjglover
Posted on Saturday, June 19, 2010 - 11:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
much appreciated, will put up some pictures when i am done my project
Post Number: 1210
Posted on Sunday, June 20, 2010 - 09:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You can search for lubriplate on here and find a ton of info.
Specifically take a look at this one.
http://www.oldmarineengine.com/discus/messages/5/133050.html
I had to take the 3 HP Gray out of my boat and clean the grease channels out. Grease cups should NOT need anything other than your hand to turn to lubricate the mains. I use plain old wheel bering grease from the auto parts store.
Lubrication technology has changed and for the better I might add.
Hope this helps
Matt Glover
Username: mjglover
Posted on Sunday, June 20, 2010 - 09:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
sound good, i was told wheel bearing grease was ok to use but i didn't want to try it, not being sure, and ruin my bearings.
Post Number: 1211
Posted on Sunday, June 20, 2010 - 03:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
An additional note my 3 HP Gray is an NOS engine not rebuilt but NOS so the mains are tight. On an engine with some wear the thicker grease may be ok. I say may because you need to confirm that it is actually getting into the main bearings. Also on an engine with wear thicker grease will assist in sealing the main bearings to the crankshaft.
grant strong
Username: grant_s
Post Number: 13
Posted on Monday, September 05, 2011 - 12:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hey Matt I have a 20 foot motor boat with 5 layers of fiberglass no wood and i find her just fine. About the grease, wheelbearing grease is fine, it keeps a car on the highway doing 100 km/h so i'm sure it can keep our motors going.
Robert
Username: robert
Post Number: 442
Posted on Monday, September 05, 2011 - 08:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If you have a NOS engine that never had salt water in her you have a rare thing indeed. Whatever you don't don't let salt water get into her now. Put on a keel cooler and run anti-freeze.
What's the hull type? A Bush Island Boat sort of shape?
