Kermath Sea Wolf
Old Marine Engine » Kermath » Kermath Sea Wolf « Previous Next »
Bob Johnson
Posted on Friday, November 30, 2001 - 08:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This week we have finally started to investigate the internal condition of our 1927 Kermath Sea Wolf installed in a 27' Chris-Craft runabout. The engine was not used since 1978. It was not seized (!) and shows very minor rusting on the camshaft and cam followers only. It was drained of oil when laid up, and there seems to be about 1 gallon of oil in the bottom of the pan and a little more in the oil reservoir. No nasty noises when we rolled it over on a wrench. Question... Do we need to replace the existing valve seats with hardened seats to compensate for the lead-free gas? Could the cam and followers be polished clean or do we need a rebuilt cam, since there is minor galling on the lobe tips. All suggestions welcome.
jmj
Posted on Saturday, December 01, 2001 - 08:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi!
It's usually recommended to replace the valve seats though there have to be enough material left around the new seat. It's best to make the new seat as small as possible.
The camshaft could be hand grinded with a fine whetstone (knife sharpening tool) if the rust isn't too deep. Grinding away .002" (0.05mm) or .004" will probably not affect the engine power.
Bruce Hall
Posted on Saturday, December 01, 2001 - 10:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bob,I think you will find the seats are already very hard.I think marine fuel of the Sea Wolf era was "White Gas" which was unleaded.You might be able to dress the cam and adjust the tappets for compensated valve clearence.Post your question to the Kermath and Sterling engine website.
Robert Holcomb
Posted on Sunday, December 02, 2001 - 06:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Where is the kermath site at????
Posted on Sunday, December 02, 2001 - 06:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Robert,
Rich Langtry has a site with Kermath information at: http://www.kermath.com/kermath_marine.htm
Also we offer some Kermath manual reprints at here.
Regards,
Andrew
dave
Posted on Saturday, October 19, 2002 - 08:09 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You might also drop a line to the Antique Boat Museum in Clayton requesting they send you a copy of the Kermath Sea Wolf Manual. I know they have one as I was looking at it a couple of weeks ago. They are in the middle of a move right now so it might take them a bit to locate it.
Regards
Dave
Brad
Posted on Monday, January 06, 2003 - 09:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Often times the followers on the Kermath sea wolfs are dimpled in and need to be reground for they sjould be a smooth radius outward and the cam sould be done at the same time the shop that does this Lester Prairie engine PH 320 395 2881 the guys name is Les. As for the seats in a Kermath don't worry they are hard enough. Les has done many complete rebuilds on the Kermath seawolfs and nows them well.
P.S. neat motor take care of it
Dave Doner
Posted on Sunday, August 22, 2004 - 10:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Kermath Sea Twin (serial # 11055RG) which I plan to install in a small launch. I would like to obtain information on this engine such as age, as-built photos and/or manual, specifications, etc.
Bob Johnson
Posted on Tuesday, September 28, 2004 - 08:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Finally started our Sea Wolf on Saturday. After some fooling around with the distributor (no spark) we found that the condensor was shorting out on the case. Once fixed, it started right away after a 25 year sleep. Sounds wonderful, especially at the end of the 4 inch exhaust pipe. No thumps, no rattles, just a nice old engine brought back to life.
poker casino352
Posted on Monday, March 06, 2006 - 06:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 257
Andy S
Posted on Friday, July 27, 2007 - 08:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone know if the www.kermath.com website is down or has moved as I can not get it to respond?
Regards
Andy
