Bridge Type B
Old Marine Engine » Unknown Engines - post here with photos » Bridge Type B « Previous Next »
Philip Holmes
Username: barossa_valley_machinery_preservation_society
Posted on Monday, August 13, 2007 - 09:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Wanted known any information about engine with BRIDGE TYPE B on it. Has 3 cylinders appearing to have atmospheric inleet valves and a side exhaust valve. On fly wheel end there is provision for starting by crank and on opposite is a distributor which is driven off the camshaft for ignition and also a water pump also driven off the camshaft with a bevel gear. Inspection points on side for possible adjustment of bearings and appears to have an oil pump which goes to the bearings. Need any information at all!
