Gray marine A600 express six 244
Old Marine Engine » Multi Cylinder Gas Inboards » Gray marine A600 express six 244 « Previous Next »
spoon
Username: spoon
Posted on Wednesday, March 22, 2006 - 01:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i need to buy an A600 244 gray engine the head measurements are 25.5 x 8.125 inches the F600 244 is a smaller block 24 x 7 inches i need one cheap as freight will kill deal call me at 970 345 6823 nelson thanks even a head would be ok as i will shave it
webb
Username: webb
Posted on Thursday, March 30, 2006 - 03:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 6cyl engine and want to get rid of it. Grey Marine F800A. Maybe some one would like to rebuild it, or just run it as is. The guy I got it from had it running 2 years ago just to see if it worked.
ww2surplus
Username: ww2surplus
Posted on Monday, June 25, 2007 - 08:41 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello I am looking for a Bell housing for the express-six 244 engine can anyone help please!?
bhendrix
Username: bhendrix
Posted on Monday, July 30, 2007 - 06:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Since the 244 Express is a typical flywheel forward engine, I assume you are talking about the housing over the output shaft. That was part of the forward/reverse gear housing since it shared the oil supply with the engine. An available option was a Velvet Drive unit which was coupled by an adaptor ring (using its own oil supply). I ended up having to have the adaptor ring and shaft coupler custom made for mine. I got it through Bristol Services in Southern California who worked with a local machine shop. It took them about a year and a half, but they probably still have the measurements.
If you are looking for a flywheel cover, I have one I can loan you to get a duplicate casting made.
