Petter PJ3W
Old Marine Engine » Diesel Inboards » Petter PJ3W « Previous Next »
nbmike
Username: nbmike
Posted on Sunday, October 14, 2007 - 03:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi. I have recently built a narrowboat for use on UK canals. I have an old Petter PJ3W stationary engine that I am in the process of marinising. I have connected up gearbox and drive to prop shaft but am still missing the variable speed governor weights. I have the fixed speed weights that are installed in the engine but am having great trouble finding what dimensions they need to be machined down to. It has pretty fine tolerances because the manual states a weight difference of not more than 1 gramme. Can anyone help with these dimensions please
listerdiesel
Username: listerdiesel
Post Number: 18
Posted on Monday, November 26, 2007 - 04:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You should be able to vary the speed of the stationary version in the same way as the marine, there's not that much difference at all and I'd be surprised if you cannot just fit a lever/control the the existing governor housing lever and go with it.
I've got the PJ handbooks, I'll have a look at them when I have a minute and see what gives.
Peter
nbmike
Username: nbmike
Posted on Tuesday, November 27, 2007 - 02:34 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Peter. Any help would be much appreciated as my 60 ft narrowboat is still tied to the bank!!!
Mike
denboy
Username: denboy
Posted on Tuesday, April 01, 2008 - 05:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi mike were abouts are you i took a pj3 out of my boat last year and have a few bits and pieces lurking about that may come in handy, as spares are not easy to find
