Tom Sanders
New member Username: tom1800_1
Post Number: 1 Registered: 07-2007
| Posted on Monday, July 23, 2007 - 01:45 pm: |
I have brought A boat with A 55mea engine, 10hp at 1650 rpm. have got the engine started and running well but engine revs do not increase when in forward, but do in reverse. can anybody help with this problem ? |
Peter Ogborne
Post Number: 208 Registered: 09-2002
| Posted on Monday, July 23, 2007 - 07:27 pm: |
Tom ,my first reaction to your problem is that something in the throttle linkage is ''Sticking''.As you would be aware the same throttle settings are obtained with the throttle lever set whether you are in forward or reverse.I will have alook at mine but from memory one setting if not both depend on spring tension..................Just went and had a look. If you engage astern and then forward the throttle collar and screw should move identical distances.This movement in and out controls the amount of opening in the venturi. If the opening distance is not the same check the spring tension also that the connecting links are not sticking.........if all this is ''Dutch '' to you let me know and I will try and explain it a little better. |
Post Number: 266 Registered: 07-2002
| Posted on Monday, July 23, 2007 - 11:18 pm: |
Does your gear have a lower reduction in reverse than forward? If so, you may be down on power for some reason. |
Peter Ogborne
Post Number: 209 Registered: 09-2002
| Posted on Tuesday, July 24, 2007 - 07:13 am: |
A good suggestion JB .My memory is getting bad . A case recently had the same problem and it was resolved by cleaning the prop. |
Tom Sanders
Post Number: 2 Registered: 07-2007
| Posted on Wednesday, July 25, 2007 - 01:34 pm: |
Thanks for your replies, will be back down the boat this weekend, will let you know how I get on. |
Tom Sanders
Post Number: 3 Registered: 07-2007
| Posted on Monday, July 30, 2007 - 12:50 pm: |
Turned out to be nothing more than A dodgy plug lead, going like a dream now. Thanks all for your replies. |
