Distributor identification
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Distributor identification « Previous Next »
Tim T.
Posted on Monday, April 10, 2006 - 08:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Please help with distributor identification. ID plate is missing. Engine is Gray Marine Phantom 4-75. Gray Marine # D 2418. Continential Plate #F4 162 25858. I'm interested in upgrading to electronic ignition and appreciate any help.
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 141
Posted on Tuesday, April 11, 2006 - 12:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There are tractors with the same distributor parts so company's are makeing kits to fit.Petronic has one.The books i have show autolite numbers so you would want a kit that fits a massy harris 30 or 33.There should be a link somewhere on www.ytmag.com
Kenneth Guest
Username: ken_guest
Posted on Tuesday, April 11, 2006 - 05:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i have a gray sea scout 4 engine #c4804 and would like to find a head gasket the existing gasket is a victor Y400 A 412M, I can't reference this anywhere, also i have a GB-1241 distributor cap but cannot find the rotor button AL 102, are there any substitutes?
Lawrence T Wolfe
Post Number: 142
Posted on Tuesday, April 11, 2006 - 07:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Search down the list on grey engines and there is a post on head gaskets.My book shows the rotor as al 104, NAPA has them listed,valubilt has them in a kit.My book allso lists the cap as al 110.
Lawrence T Wolfe
Post Number: 143
Posted on Tuesday, April 11, 2006 - 07:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If you need to ID a distributor on a 4 cylinder contintial engine.If its a delco it would have 2 spring clips on the outside holding on the cap.If it has 2 screws holding on the cap its most likely an autolite.
max rogers
Username: marogers
Posted on Friday, July 20, 2007 - 03:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Gray Marine Phanyom Six-112, 226 cu " engine which seems to miss a little at full throttle. I recently had to replace the tach cable and now instead of about 2800-2900 RPM's Im only getting around 2400 RPM's. The spec says maximum horsepower is at 3600 RPM's but I never seen anthing close to that. I have reset the distributor gap to 020 as the spec calls for but I don't really know what the dwell should be. Anybody have any thoughts/advice/etc?
