BLAXLAND 3.5 PUP
Old Marine Engine » Blaxland » BLAXLAND 3.5 PUP « Previous Next »
DRUE REED
Username: sunk1
Posted on Friday, December 21, 2007 - 07:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
HOW DO I REMOVE STARTING PULLEY FROM CRANKSHAFT
David Myers
Username: dave_myers
Post Number: 32
Posted on Saturday, December 22, 2007 - 03:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Drue,
Get a block of hardwood and a large hammer and where the pin is for the strap to hook on to give it a sharp hit to the left and the pully assembley will screw off. The Flywheel is a different story though. It is on a Taper and is usually siezed to the crank. If you have Oxy gear available, heat it up on the hub and give it a good clout from behind and it should come off.
Hope this helps.
Dave.
DRUE REED
Username: sunk1
Posted on Friday, December 28, 2007 - 09:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
YEAH I SMASHED THE STARTING PULLEY I THINK MY HAMMER WAS TO BIG ALL I NEED NOW IS A TIMING GEAR COUPLING AND A CARBY FLOAT THEN I CAN PUTT PUTT ONCE AGAIN ALL HELP GREATLY APPRECIATED
Robert
Username: robert
Post Number: 195
Posted on Saturday, December 29, 2007 - 07:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Or if that doesn't work, disassemble and support the flywheel on it's hub, not flange, in a hydraulic press and press the wheel off.
Sometimes it's easier to take the longer and safer route than taking the shorter and then spending a long time trying to fix what we broke when trying to cut corners. I should know...;-)
Give the metaphors a good stir I say!)
