Electric Fuel pump for a 272 Y-block ...
Old Marine Engine » Boats with Early Inboards » Electric Fuel pump for a 272 Y-block interceptor in a 1959 Beuhler Turbocraft « Previous Next »
hardluck
Username: hardluck
Posted on Wednesday, June 22, 2011 - 01:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am replacing the electric fuel pump in my 1959 Beuhler Turbocraft Jet Boat and was wondering what size of pump I needed to replace it with. I put a small one on it already that puts out 7psi and it can't keep up.
bruce
Username: bruce
Post Number: 266
Posted on Wednesday, June 22, 2011 - 04:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Justin, best take your question to marineengine.com This site caters to pre-WW2 marine engines.
larry_from_maryland
Username: larry_from_maryland
Post Number: 458
Posted on Thursday, June 23, 2011 - 12:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
5 to 7 psi is what i would recomend.Are you sure you have no restriction or leak in the supply line.If you go to a higher psi you risk the needle valve not holding and flooding the engine.You might need a higher volume pump.
gonzo
Username: gonzo
Post Number: 12
Posted on Thursday, June 23, 2011 - 08:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The problem is not the pressure but the volume of the pump. Calculate how much fuel you use at full throttle, add 25% and that should be the rated flow.
