New Toy
Old Marine Engine » Boats with Early Inboards » New Toy « Previous Next »
Post Number: 452
Posted on Sunday, September 03, 2006 - 06:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Pics of new toy.
You never know what you will find on Craigs List.
21 ft long I think I am going to put a Gray 3 hp model U in it for a start. It sarted life with a steam engine in it then was being converted to electric. Now a one lunger.
oblong
Username: oblong
Post Number: 9
Posted on Sunday, September 03, 2006 - 08:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
nice find
bob
Moderator
Username: andrew
Post Number: 712
Posted on Sunday, September 03, 2006 - 08:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks great Ernie!
It's fiberglass right?
The hull looks like it has a lot of bouyancy aft which will work well for whatever you put in it.
Who built the hull?
Post Number: 453
Posted on Sunday, September 03, 2006 - 09:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yup it is fiberglass. Not shure who built it. I can find a lot of them on the NET that are similar but not quite the same. I am going to put a late Gray "U" 3 hp in it.
Same as the pics below. I can't find a pic of mine right now.
Post Number: 454
Posted on Sunday, September 03, 2006 - 09:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Gray engine pics like mine. Can't find a pic of mine right now.
rosey
Username: rosey
Posted on Monday, September 11, 2006 - 02:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It looks like a smaller version of a Stanard Bros Ferry that operated on Sydney Harbour in the early 20th century. In fact there were alot of boats like this built in Australia. Mostly timber of course. I will try and take a pic of the 1889 version which is lying in Lake Macquarie. Sure would like one myself.
Post Number: 526
Posted on Wednesday, December 27, 2006 - 11:48 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Well it's finally getting an engine.
The engine is in place temporaryly to confirm my floor frame patterns are correct. Note the floor frames are low. It's easier to shim the engine up than to lower the floor frames. Or maybe at some time a different engine??? Once the engine is in it still needs tons of work. It include removing all the blue paint. You can see some of the seat framing is in for the bow and stearn seats.
Prop stuffing box and rudder
Waiting for the fiberglass to cure
I have finally confirmed that it is a "Rose" This style of fantail has been built by several people. It is 20ft by 4ft3in.
Currently you can purchase one from Lloyd Beckmann in Wakefield, RI
http://www.steamboating.net
Post Number: 527
Posted on Wednesday, December 27, 2006 - 12:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hummm...The engine still fits and the shaft even bolts up.
oblong
Username: oblong
Post Number: 10
Posted on Wednesday, December 27, 2006 - 07:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks good ernie moving right along with it
let me know when you launch it i'll give you a hand .if you need one before that call
bob
richardday
Post Number: 446
Posted on Thursday, December 28, 2006 - 08:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nice work Ernie, Bring it to CMM and we can have cruise on the Creek. I have a nice copper gas tank if you are looking for one. Be glad to give it to you. but you have to dig it out from under all the other junk.
Post Number: 529
Posted on Friday, December 29, 2006 - 07:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard,
OK thanks
glad to see you got your puter working
Post Number: 533
Posted on Friday, January 12, 2007 - 09:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Finally the engine is part of the boat.
Post Number: 216
Posted on Friday, January 12, 2007 - 08:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks good so far Ernie, are you going to launch it this spring? The one lungers are nice, nice sound, but they can get rough at max rpm.
Moderator
Username: andrew
Post Number: 824
Posted on Friday, January 12, 2007 - 08:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks good... !
Post Number: 534
Posted on Saturday, January 13, 2007 - 08:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yup I hope to have it running for spring. I need to fabricate the jacketed part of the exhaust. Also put in battery and fuel. For fuel I think I am going to use an outboard motor fuel pump and an outboard tank. I have done that in the past and it works well. The Blue has to go! However that will be after it is done mechanically. The deck will never be able to be varnished. Probally paint that tan. However the coaming, toe rail and rub rail are mahogany and should clean up ok.
As to vibration the engine beds are 3 layers of 3 quarter plywood laminated with epoxy. They are bedded in some fiberglass mush so they have 100 percent contact with the the hull. The glass work is multiple layers of mat and 24 oz woven roving. All this is done with vinylester resin. Vinylester is like polyester except it is closer to epoxy in it's molucular makup. (as I understand) It smells the same as polyester, however it is a lot nicer to work with.
johnny
Username: johnny
Post Number: 80
Posted on Monday, January 15, 2007 - 06:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nice Job Ernie! Looks great! I believe the Vinylester does not cure as brittle as polyester more plyable but tough like epoxy.
Post Number: 573
Posted on Wednesday, February 07, 2007 - 07:54 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Exhaust pic
If anyone needs flanges here is a link. They are cheap. The bronze ones I used were 26.00 with shipping.
http://pexsupply.com/CategoryPre.asp?cID=288&brandid=
Post Number: 258
Posted on Thursday, February 08, 2007 - 04:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hey Ernie - on my old boats, I inject the engine cooling water as close to the engine as I can.It looks like you've got a fairly long run of hot pipe before you get to the muffler. I made an elliptical hole in a standard elbow and brazed in a 3/8 pipe to take the cooling water. It is all sloped downward to prevent water getting back into the engine. I also found that using clear tubing on the suction side of the water pump lets me see if water is getting sucked in.
But a really good new toy.
barry
Username: barry
Post Number: 37
Posted on Thursday, February 08, 2007 - 05:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie,
I have been following your project with interest and much admiration.
Two-cycle engine exhaust is a subject that interests me.
Your recent image suggests muffler placement about parallel with prop shaft, therefore below LWL. The image also suggests engine cooling water will be injected into the muffler.
I am very interested to learn where you will exit the exhaust from the hull and how you will overcome backpressure both during engine starting and also during engine operation as a result of accumulation of water in the muffler that must be lifted above water line.
I have tested water lift mufflers with 2-cycle engines and am currently engaged in research and study of the issues. Your experience and be very helpful.
Regards
Barry
Post Number: 579
Posted on Thursday, February 08, 2007 - 06:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Barry,
I have been installing 2 stroke engines in boats for the last 30 years. Never noticed a problem. If the engine was really below the water line I used a vaccuum break between the water injection point and the engine.
This one isn't really a water lift muffler. Still I don't anticipate a problem. Placement is more for cosmetics and quiet than correctness. If it proves to be an issue I will simply shut off the water intake before shutting of the engine. That should result in most of the water being blown out of the exhaust. Not sure where the outlet will be. Once again cosmetics. It will however be above the water line. The high point at the engine is also above the water line. There will be surflex hose between the muffler and the through hull fitting.
Post Number: 582
Posted on Thursday, February 08, 2007 - 07:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I really havn't decided where I am going to inject the water. Miro you are correct it is easy to inject the water closer to the engine. I may jacket the riser. I have to decide which is easier, jacket it, heat shield it or inject water at the top (down far enough so it can't get back to the engine). I am going to use reinforced clear or a little clear water filter that I have. Maybe both for the reasons you mention on the intake.
Post Number: 261
Posted on Saturday, February 10, 2007 - 07:45 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hey, Ernire, have a look at the discussion our Aussie compatriots had on shaft and engine alignment
http://www.oldmarineengine.com/discus/messages/3452/101151.html
You probably know all about this, but I found it very useful as a refresh
They've got summer tme now - I've got 4 ft of snow and 2 ft of ice on the lake.
Let's hear it for global warming :=}
Post Number: 585
Posted on Saturday, February 10, 2007 - 01:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
No snow, just the ice here. Yup warm is good.
Thanks, however as far as alignment goes remember this one is plastic. It's aligned now. I will check it once it's in the water. However I have yet to see one of these small fiberglass boats change shape when going in the water. Not saying they can't or won't, just never seen it happen. Not sure, but I think the 1st one I did was in about 1976.
Post Number: 635
Posted on Sunday, April 29, 2007 - 09:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Getting closer to the water.
johnny
Username: johnny
Post Number: 106
Posted on Tuesday, May 01, 2007 - 08:13 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie,
The boat is coming along good, makes me want to build one bad. All I need is the time,money and place to store it.
Post Number: 636
Posted on Tuesday, May 01, 2007 - 10:55 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It is even registered! I hope to have it in the water in the next week or so.
johnny
Username: johnny
Post Number: 107
Posted on Wednesday, May 02, 2007 - 10:15 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie,
I have a few questions for you about your boat but berfore I ask keep in mind that I know nothing about building boats or mounting a engine in a boat other then when I was younger I built a few radio controlled wooden and fiber glass boats. How ever I do know a little about composites, fiber glass, carbon graphite, kevlar, resin's, epoxies, polyesters, etc.. learned from my job and fiends. First question: what type of wood are the two engine mounts made of? some kind of hard wood? spruce,oak? Do you have blind nuts with stakes in the two wooden rails that are covered with fiber glass for the engine bolts to screw into? Lag screws would never hold would they?
Post Number: 637
Posted on Wednesday, May 02, 2007 - 12:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The engine beds are 3 layers of 3 quarter plywood laminated with epoxy. They are bedded in some fiberglass mush so they have 100 percent contact with the the hull. The glass work is multiple layers of mat and 24 oz woven roving. All this is done with vinylester resin.
The engine is bolted to the bearers with 3/8 x 5 stainless lag bolts. There is 3 inches of thread into the bearers. In a fiberglass hull you use plywood not regular wood when glassing it in. Plywood is dimensionally stable. Plain oak or pine isn't and will ultimatly crack the fiberglass that is bonding it into the hull.
As to the holding ability of lag bolts, that was the primary fastener to mount the engine in most wooden boats since engines were mounted in them.
If the lag bolts are ever a problem I have room to cut slots through the bearers and slide in nuts welded to a little piece of flat plate.
Post Number: 660
Posted on Friday, May 18, 2007 - 07:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Finally all the woodwork and glasswork is done. Need to hook up the exhaust, fuel and ignition. Also heat shield the exhaust from the engine to the muffler.
Then paint the woodwork.
Post Number: 680
Posted on Tuesday, June 26, 2007 - 08:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Finally got the new wood painted. I removed the muffler. The exhaust will be 7 feet of Surflex exhaust hose. I think that will quiet it enough. Not sure what I am going to do with the inside of the hull for a finish. However I am not going to do anything untill I am sure I don't need to do any more fiberglass work.
Post Number: 282
Posted on Wednesday, June 27, 2007 - 01:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
nice work ernie .
time to get'er wet
. . miro
Post Number: 681
Posted on Wednesday, June 27, 2007 - 04:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Miro,
Thanks I am on vaca in a couple of weeks. Gonna do it then.
Post Number: 682
Posted on Friday, June 29, 2007 - 02:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
More pics
I rolled it outside today. Arggggggg.....The sun brought out a lot of things I hadn't seen.
Whoever did the glasswork on the bulkheads was better at creating runs and drips than spreading resin. It's going to be a ton of work to get the cosmetics done. Oh at least I will have something to do after it is in the water.
Post Number: 683
Posted on Tuesday, July 03, 2007 - 02:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It even runs
The silver thing by the timer is the fuel pump. It's from a Briggs and Stratton and runs off crankcase pressure fluctuations.
Once it starts pumping water out the exhaust it is nice and quiet.
Post Number: 685
Posted on Sunday, July 08, 2007 - 04:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think it's done. That is done enough to go in the water.
These will be the last pics on this thread. It's too big anyway. I will create a new one for when it's in the water.
johnny
Username: johnny
Post Number: 109
Posted on Sunday, July 08, 2007 - 05:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie,
Good luck and have fun...wished I could be there to see it go for the first time. Thanks for sharing the photos and process with us..
Post Number: 688
Posted on Monday, July 09, 2007 - 04:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
More pics click here
rosey
Username: rosey
Post Number: 34
Posted on Monday, July 09, 2007 - 06:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The boat looks great mate. What is the draft and beam on her?
Post Number: 690
Posted on Monday, July 09, 2007 - 06:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Draft is about 11 inches and beam is 4 ft 3 in
rosey
Username: rosey
Post Number: 35
Posted on Monday, July 09, 2007 - 07:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
For all those under 40 in Aussie thats a draft of 280 mm with a beam of 1.3 metres.
Thanks Ernie
