Dynostart Wiring
Old Marine Engine » Diesel Inboards » Dynostart Wiring « Previous Next »
David Wells
Posted on Tuesday, July 11, 2006 - 12:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello,
Can anyone help me with a wiring diagram for a Dynostart (mine is fitted to a Yanmar PMX8)please?
Thanks and Regards
David
david_stott
Username: david_stott
Post Number: 8
Posted on Tuesday, July 11, 2006 - 07:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
David. Have sent you an email this morning, with info which might help.
limeydave
Username: limeydave
Posted on Monday, July 09, 2007 - 10:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yet another dynostart wiring request. This one is fitted to an air-cooled single Ducati diesel in a British "Springer" narrow boat. It works OK as a starter so the dynamo function may well be good but the wiring has all been damaged. It has a brown wire on one side and a green wire and a red wire on the opposite side. There is a disconnected Lucas RB340 regulator installed but ,again, the wiring is all removed. However, the previous owner (now deceased and therefore beyond questioning) was positive that all worked previously. Any wiring diagram or ideas on how to connect it all up again would be very welcome.
Dave.
