Gray marine 427 chrysler
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray marine 427 chrysler « Previous Next »
brook goss
Posted on Tuesday, August 22, 2006 - 09:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a gray marine motor i don't no the exact date and iwas told that it is a 427 crysler motor i would like to find more info about this
i would like to know if there is a way to convert it to mercruiser outdrive
Robin Valenzuela
Posted on Monday, August 28, 2006 - 12:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just bought a 1920 Morton Johnson Lapstrake life boat somtime back someone put in a Gray inline 4 . Number on block F4000A330 number on transmission plate 98116 could someone help with the year of the Gray Thank You
David Conwill
Username: david_conwill
Posted on Monday, May 07, 2007 - 07:09 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
At least in passenger cars, Chrysler never made a 427 cubic inch engine. They made 413s and 426s though (among others), as well as a 426 Hemi (similar block, different heads). A picture would probably be helpful.
-Dave
Bruce Hall
Username: bruce
Post Number: 142
Posted on Monday, May 07, 2007 - 08:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Robin, My reference places your Graymarine motor as a late 1939 production model
