Pan Gasket source - V8CF-195? |
gene porter
New member Username: gporter
Post Number: 3 Registered: 03-2006
| Posted on Friday, April 27, 2007 - 08:40 pm: |
Can't stop the oil drips, so will pull engine out of Lyman try a new pan gasket. Need advice on where to buy what kind of gasket (This is the AMC 327 block) Thanks Gene |
David Conwill
| Posted on Sunday, May 06, 2007 - 04:05 pm: |
I don't know if this helps: 1960 AMC (Rambler) Ambassador with a 327 pan gasket lists as Item # NGAOS30569 for $10.69 on the NAPA website. Assuming the blocks are the same between the passenger car and the marine engines, I would think that should work. -Dave |
