Rebuilt an Outboard- to an Inboard en...
Old Marine Engine » Multi Cylinder Gas Inboards » Rebuilt an Outboard- to an Inboard engine « Previous Next »
wichmann
Username: wichmann
Post Number: 12
Posted on Thursday, August 30, 2007 - 06:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Is there someone who have any idea about use an modern outboard engine, dismantle it, and use it as an inboard engine? Is it posible. About 60 hp.
Post Number: 274
Posted on Thursday, August 30, 2007 - 07:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Modern outboards use a 2 to 3 to 1 reduction in the lower unit. If you were to attempt this conversion you would need a gear with a similar reduction, an adapter plate to handle exhust and cooling water, and a splined shaft to match the crankshaft. It could be done but if you have to pay to have it done you could buy an inboard set up.
wichmann
Username: wichmann
Post Number: 13
Posted on Friday, August 31, 2007 - 05:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ok. but is there anyone who hav done that?
mrpos
Username: mrpos
Post Number: 11
Posted on Friday, August 31, 2007 - 08:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
OMC used outboard powerheads as "inboards" on some jet powered boats.
