1955 Gray Marine 6cyl
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » 1955 Gray Marine 6cyl « Previous Next »
Dan Jeffries
Username: drydock
Posted on Friday, March 16, 2007 - 10:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Flat Head model #616, for anyone who wants it. It was in running condition when I switched my boat over to diesel.
The motor & transmission has been stored undercover since it was removed. I'm located in Toronto Canada. It hate to scrap it if someone wants it.
lotus f1
Posted on Monday, April 02, 2007 - 12:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Dan
I'm in need of an exhaust system for a 17.5' Shpeherd/Gray, 6 cylinder, Vee Drive.
You got?
Mike Beale
Dan Jeffries
Username: drydock
Posted on Monday, April 02, 2007 - 06:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Mike,
Sorry, No exhaust available.
David Conwill
Posted on Sunday, May 06, 2007 - 10:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Dan,
What size is your 6 cyl? I am looking for a Continental F226 L-head 6 cyl and I understand the Gray Marine engines were based on Continental blocks.
Regards,
Dave
stiles meredith
Posted on Saturday, May 12, 2007 - 05:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone know the horse power of a model 671? Is it 100? Looking for an engine for a 1955 Lyman 18 foot runabout. Am told that a 109 HP will also fit.
Bruce Hall
Username: bruce
Post Number: 143
Posted on Sunday, May 13, 2007 - 10:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have you tried tried the Lyman Boat Club based in Ohio to see what the engine options were in '55 for the 18'model? If the engine stingers look like they once had a six cylinder- I'd expect it was a Model 100 Graymarine.
Post Number: 648
Posted on Sunday, May 13, 2007 - 04:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
From memory MANY years ago the 18 was called an Islander. The Islanders I remember had little 4 cylinder Grays.
