What is it's function???
Old Marine Engine » Diesel Inboards » What is it's function??? « Previous Next »
joost
Username: joost
Posted on Wednesday, March 14, 2007 - 06:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a question about the function of a part of my engine. On the photo below, there is an air inlet left of the sprocket. On top of the ilet, there is a small red "cap". I am wondering what it's purpose is, when i feel inside the inlet, there's a little iron tube that goes into the engine.
The there is another wuestion, what could be the best way to start this engine? It eventually does start and sounds regularly, but the amount of energy i have to put in slinging the flywheel around is horrific. Does anyone have a solution for my problem?
Joost Vermaat (The Netherlands)
Post Number: 612
Posted on Wednesday, March 14, 2007 - 08:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It is most likely to add some engine oil to make starting easier. Usually 1 squirt from a pump oil can is just about right.
Hope this helps
richardday
Post Number: 480
Posted on Wednesday, March 14, 2007 - 08:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Seems to me most hand start diesels have a compression release so you get it spining and the hit the compression release.
Simon p.
Posted on Tuesday, May 01, 2007 - 08:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Beste Joost,
Het is inderdaad de bedoeling dat je olie injecteert via dit pijpje, voordat je start. Vervolgens met de kleplichter omhoog en vol gas een keer of 6 ronddraaien, vaart maken en de kleplichter neer. Dan zou hij meteen moeten aanslaan.
Groeten, Simon.
