1941 Chrysler Crown 6 117hp
Old Marine Engine » Multi Cylinder Gas Inboards » 1941 Chrysler Crown 6 117hp « Previous Next »
brian
Username: brian
Posted on Saturday, June 25, 2005 - 04:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello all, I'm trying to figure out how the ignition wires should correctly attach to the spark plugs. I've seen it done with Raja ends, knurled nuts holding down clips, and common 90-degree boot-less ends. I also need a factory photo or spec sheet to prove however it was done.
Thanks for any input.
[email protected]
Posted on Friday, April 13, 2007 - 11:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hay i got a 1941 chrysler and i got the book
autommobile repair manual that came with the car
i found alot of the suff i need was right
on the internet.
joe
