Crankshaft pulley removal??? |
Arnie Burnham
| Posted on Tuesday, February 27, 2007 - 11:42 pm: |
Any suggestions for removing the pulley off the crankshaft of a Graymarine 4-45 or other Graymarine engine. I'm afraid to use a three arm gear puller because of the thin edge of the "V" where the puller would be pulling. I have removed the key set screw and have applied PB Blaster to loosen up some of the corrosion. Thanks, Arnie |
Bruce Hall
Senior Member Username: bruce
Post Number: 134 Registered: 07-2002
| Posted on Wednesday, February 28, 2007 - 07:47 pm: |
I've had success on simular applications with putting tension on the pulley with a puller and then setting a punch to the center of the shaft and striking the punch with a swift blow from a one pound hammer. Generaly it breaks the pully loose in order to be pulled with the puller....be certain the surface of the shaft is sanded clean and lubed |
