Need Crown copper manifold
Old Marine Engine » Multi Cylinder Gas Inboards » Need Crown copper manifold « Previous Next »
rendo
Username: rendo
Posted on Thursday, August 31, 2006 - 09:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for same. Thanks. John 484-459-0880
shawnstam
Username: shawnstam
Post Number: 16
Posted on Tuesday, January 09, 2007 - 12:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
have you considers haveing one made, those things are almost impossible to find.
a good fabricator should be able to tig weld one together for the right price.
good luck
shawn
Moderator
Username: andrew
Post Number: 823
Posted on Tuesday, January 09, 2007 - 09:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There is a place on Long Island, NY that specializing in marine manifold fabrications. I can dig out the name and phone number if you need it.
Pete Podoloff
Posted on Friday, January 12, 2007 - 05:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
http://www.marineparts.com/mpf/mpf272.aspx
This company has parts for the old hercules engines AKA Chrysler crown & Chris Craft Model K
