Unknown 3 Cylinder Racing Engine
Old Marine Engine » Unknown Engines - post here with photos » Unknown 3 Cylinder Racing Engine « Previous Next »
Keith Billet
Username: keith
Post Number: 151
Posted on Sunday, October 22, 2006 - 06:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just picked up this Three Cylinder Copper Top Engine. There is no name tag or number to identify the engine. There are several features that suggest it is a performance engine. One, it has removable plugs in the exhaust system for straight exhaust pipes. Two, it has castle nuts bolting the cylinders to the base. It is of lightweight design with aluminum used for the base and intake manifold. The exhaust manifold is cast iron with a copper jacket soldered around 3/4's of the manifold (no core cast for water). It has a 1-1/2 inch 5 ball Kingston Carb and a Bosch Mag. The mag and water pump are driven by bevel gears. The pump from the rear and the mag from the front. I can send better pictures.
Keith,
3
4
5
6
7
Roger DiRuscio
Username: solarrog
Post Number: 208
Posted on Sunday, October 22, 2006 - 06:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for posting these, It will look great after polishing and painting
William Schaller
Post Number: 93
Posted on Sunday, October 22, 2006 - 07:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Great looking motor. Do you know the area it is from? Those 3 cylinder mags are a little hard to come by, too.
Post Number: 188
Posted on Sunday, October 22, 2006 - 08:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nice find Keith, I agree it's a high performance engine, looks like another 2 port-3 port.
Post Number: 1271
Posted on Monday, October 23, 2006 - 06:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Keith
Great engine ! I believe its a 1910-11 ERD MOTOR CO. Saginaw Mich.
I will be back home tomorrow or Wed and confirm it and post what info i have !
Post Number: 479
Posted on Monday, October 23, 2006 - 07:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I agree with Richard. The cast iron piece between the cylinder and manifold shure looks Erd. Richard can you take a pic of your single and post it?
Post Number: 1273
Posted on Monday, October 23, 2006 - 10:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Found the ERD photos in the archives Feb 2004, see post !! looks to be same 2/3 port intake !
Keith Billet
Username: keith
Post Number: 152
Posted on Tuesday, October 24, 2006 - 08:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is a better view of the intake.
1
Post Number: 481
Posted on Tuesday, October 24, 2006 - 12:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is the pic of the 2/3 port manifold on Richards Erd single.
Post Number: 1274
Posted on Tuesday, October 24, 2006 - 10:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
ERD Triple - June 1911
Et1
Et2
Keith Billet
Username: keith
Post Number: 153
Posted on Wednesday, October 25, 2006 - 08:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for the posting an ad copy Richard.
It is always nice when a neat motor, without a tag, can be identified, especially when you own it.
1
Post Number: 1277
Posted on Wednesday, October 25, 2006 - 08:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Erd six cylinder 60 Hp July 1912
ETJ121
ETJ122
Post Number: 1281
Posted on Thursday, October 26, 2006 - 12:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Keith
Haven't found any more info on your specific copper dome engine, from ads it seems that these engs came on the market mid year 1911.
This is the high speed erd that preceeded it 1910 to mid 1911.
Espeedearly11
These Erd 2/3 port engs had slots or ports in the sides of the pistons - the 2 port crankcase fuel went up through the piston and out into the cylinder ports !
This is the overhead valved eng that succeeded the copper domes, late 1913 or 14.
eov1
eov2
Keith Billet
Username: keith
Post Number: 154
Posted on Thursday, October 26, 2006 - 07:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here's an ERD I don't own, but wish I did.
1
2
Post Number: 1283
Posted on Thursday, October 26, 2006 - 09:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Now if this doesn't stir your blood Then you've mistakenly stumbled onto this web site!
Keith Great stuff Thanks for photos !!
Sindre Nilsen
Username: wichmann
Posted on Tuesday, October 31, 2006 - 04:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I`v got an old "race-boat", and dont have any race engine like this, 3 or 4 cyl. aprx. 30 hp. Is there possilble to bay any one, in an ok condition?
If not, I`m interessted in catlog or drawings of this kind of "race-engine".
Robert
Username: robert
Post Number: 138
Posted on Friday, November 03, 2006 - 01:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What a find! Seal it up and take it to the soda blaster for the quickest clean up.
Foxman
Posted on Friday, November 10, 2006 - 09:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The black Erd is mine. It is a 1910 34 hp model which cam out of "the fastest boat on the Hudson" [River in New York], This was part of a collection of a tugboat Captain who picked up engines while he visited various ports along the said river. The engine is in almost perfect original condition and needs no restoration.
Now all I need is that "fastest boat". Carbs are Holley.
Post Number: 1323
Posted on Saturday, November 11, 2006 - 11:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
ERD December 1910
e1
e2
